11/14/2017 12:18 PM | |
Posts: 2 Rating:
dear sir please i need help for connecting sentron PAC 3200 to 2PCs over scada i program it and it running OK on one PC only if in need it on the other pc i must disconnect it from the first PC ( it is not running on the two scada PCs on the same time ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/15/2017 2:58:19 PMNew subject after splitting |
11/15/2017 12:15 PM | |
Joined: 8/3/2009 Last visit: 3/27/2025 Posts: 15088 Rating:
Hello pavloti which SCADA Software do you use? do you use WInCC V7.X? do you know this one: https://support.industry.siemens.com/cs/ww/en/view/37885119 Bye Murof |
Last edited by: Murof at: 11/15/2017 12:15:21 PMIf this Information really helps, you could use the Rate function |
