8/17/2014 7:44 AM | |
Posts: 81 Rating:
Hello everyone, I need to program a PLC to control a servo motor, If any one have sample program of SCL please send me. Thanks , pavan
8/17/2014 8:45 AM | |
Posts: 5225 Rating:
Hi. Why the need to have it in SCL? You use the language that suit you best.. SCL for this case will work but will cause all sorts of hardship for you. I recommend for you to have a look at the Siemens CE-X7 example [LINK]. Greetings. w |
8/17/2014 6:10 PM | |
Posts: 5225 Rating:
But what does your question have to do with PLCs?.. it sound as if you are constructing a PC based controller? If you are, you are barking up the wrong tree. Are you looking for?.. (these are actually helpful) [LINK1] [LINK2] [LINK3] PLCs/motion controller from Siemens and Schneider Electric uses "open" coding as created in the first link. Try search terms including GNU and LINUX, you might have more success. Helpful? w |
8/18/2014 1:05 PM | |
Joined: 9/19/2011 Last visit: 12/12/2022 Posts: 134 Rating:
Have you seen this example? http://www.bytex.it/Article/eng/Complete-Solar-Tracking-example-code-with-Siemens-S7-1200-Tia-Portal.html Larry |
3 thankful Users |
