3/15/2020 6:42 PM | |
Joined: 8/19/2012 Last visit: 9/20/2023 Posts: 124 Rating:
Hi Dear. I have siwarex U-1 7MH4601-1AA01 connect with CPU 312 2 DP (6ES7 315-2AF03-0AB0) due to problem in CPU . I replaced by NEW CPU 3152DP(315 -2AH14-0AB0). the question ,Is the siwarex need calibration or not ? Best regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/16/2020 17:01:48New subject after splitting |
3/17/2020 10:03 PM | |
Thank youyou. I have that 1-Weigh belt 2- frequency converte: VLT® AutomationDrive FC 302 3-CPU 315 -2DP 4-KTP 400. Now after replacement happend in PLC and frequency converte .i tried to do tare and calibration for beltweight but not accept the Tare.belt still run without stop. See 068ZW4.at attachment . But if I do change in block FB11 network 20. the tare and calibrate OK.But the weight show wrong during material on belt . Best regards Attachmentashish.zip (27 Downloads) |
3/17/2020 10:06 PM | |
Please see network 20 that the modified. Best regards AttachmentFB11.pdf (35 Downloads) |
