4/19/2022 9:27 AM | |
Joined: 7/1/2013 Last visit: 4/11/2025 Posts: 1 Rating:
I have a similar problem. I need to disable on screen keyboard but I couldn't find how (I am using MTP700). On comfort panels I disabled the keyboard using "SetScreenKeyboardMode " command. Is there any way to do it? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/19/2022 13:31:11New subject after splitting |
11/13/2024 9:59 AM | |
Joined: 9/12/2017 Last visit: 4/17/2025 Posts: 9 Rating:
Do you any information about this theme? Is this function available now in V19? |
11/14/2024 9:26 AM | |
Joined: 7/11/2024 Last visit: 4/16/2025 Posts: 185 Rating:
Hi Kanchora, Are you using a PC Runtime or a panel? Which panel are you using? In case you are using a PC Runtime, check this FAQ: Enabling the on-screen keyboard in WinCC Unified PC Runtime But I don't know if there is a similar FAQ for panels, sorry good luck |
If this post has been useful, don't forget to rate it!😊 |
