5/16/2019 9:00 AM | |
Posts: 1 Rating:
Sorry I'm a newbie here. I'm using TM count 2x24V, we need to read the flow rate and totalized flow of the transmitter. The module is installed together with the CPU. When we tried to trigger the DI 0 we got no response on the PLC program. I just want to know the configuration for this application. Do we need to use the "high_speed_counter" block? Is there proper parameterization? Thank you. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/16/2019 14:03:44New subject after splitting |
5/17/2019 6:28 AM | |
Joined: 4/28/2015 Last visit: 10/25/2024 Posts: 398 Rating:
Hello, please have a look at the following application example.
In this example you get detailed information about the use of TM Count, including hardware and software. Maybe it will help you to get the basic informations. Otherwise you could also have a look in the manual of the TM Count...
