12/24/2017 7:06 AM | |
Posts: 4 Rating:
I am having a similar issue as above, I have inspected the 1/one temperature/level/pressure slider in the elements toolbox. This is not helpful for my needs as is, I am needing an input slider for speed control. There is a lever switch in the library that looks like what I need but only deals in on/off, not analog. Is there a way that I can download more elements or perhaps even make my own. I have attempted several times to use pieces of the lever switch, extracted into separate pictures, to make a faceplate that will service my needs. There must be some way to make your own elements when the provided elements are insufficient. I did also attempt to find a way to edit or extract the needed pieces of the provided slider to do the job. I am certain there must be a way to do this that I am just not figuring out, the provided option(s) are not exactly adequate for any possible situation! Any assistance on this would be most appreciated!! Thank you!! ------------------------------------------------------------------------------------------ |
Last edited by: wellmclain at: 12/24/2017 7:06:57 AMLast edited by: Jen_Moderator at: 12/26/2017 6:59:57 PMNew subject after splitting |
