10/27/2010 11:34 AM | |
Joined: 9/23/2005 Last visit: 1/28/2023 Posts: 4176 Rating:
Hi, I take a look at wikipedia (http://en.wikipedia.org/wiki/Thermocouple#T). The termocoupler T has a 43 microV/Celsius coeficient at a error up 1 grad. However the continous operation temperature is >185C. My suggestion: 1 - measure the voltage with a voltimeter. 2 - measure the voltage with the module. 3 - compare it. If you read voltage in module, you can use SCALE block to convert it to the correct value (/tf/WW/en/Posts/31698#top ). |
Denilson Pegaia |
