3/18/2014 5:06 PM | |
Joined: 1/21/2013 Last visit: 6/21/2023 Posts: 4617 Rating:
Hello crazy taxi, --(N)-- |
3/18/2014 5:15 PM | |
Joined: 4/11/2011 Last visit: 4/11/2023 Posts: 132 Rating:
Link to"negative RLO detection" |
I'm just a human. Mistakes are allowed. |
3/18/2014 6:21 PM | |
Posts: 16 Rating:
thank youDongerpure but i though the output will change when the I0.6 will change from 1 to 0, i mean after the object acrossed the sensor, or am i wrong?
3/18/2014 6:42 PM | |
Joined: 3/8/2011 Last visit: 5/17/2023 Posts: 262 Rating:
thank youDongerpure but i though the output will change when the I0.6 will change from 1 to 0, i mean after the object acrossed the sensor, or am i wrong? In your picture mentioned the output gets reset or goes low when your input changes from 1 to 0 i.e when the object is crossed and you loose the sensor your output goes off if you use reset bit. Let me know if got the solution. |
If this post helped you, you may use the Rate-button |
3/18/2014 7:25 PM | |
Posts: 16 Rating:
exactly. thank you very much. |
