7/9/2018 9:01 PM | |
Posts: 32 Rating:
https://support.industry.siemens.com/cs/ww/en/view/109757088 New smartlinx options, but does not look like the Multiranger 100/200 is included? Does anyone know? I would definitely be interested in a Ethernet IP option for our Multiranger 100's. |
7/10/2018 10:41 PM | |
Joined: 3/28/2010 Last visit: 10/1/2023 Posts: 977 Rating:
The SmartLinx catalog sheet lists MultiRanger 100/200 as a compatible unit in the Selection and Ordering Data in column 2. [snip] It could be a misprint, but Siemens would be morally obligated to let you return the SmartLinx card if it does not, in fact, function in a MultiRanger 100 when that model is listed on the catalog sheet. Legally obligated to let you return it? Who knows? Attachmentsitransl_smartlinx_fi01_en.pdf (84 Downloads) |
Last edited by: Jen_Moderator at: 7/11/2018 11:13:22 AMDeleted link and added file as an attachment. |
2/21/2019 3:04 PM | |
Posts: 32 Rating:
Siemens website is very confusing on this. Thanks DanW, your link indicates the Ethernet IP module IS compatible with the Multiranger 100. However, the SmartLink module instructions specifically state that it is NOT compatible. https://support.industry.siemens.com/cs/attachments/109756072/A5E43778525_EN_en-US.pdf?download=true Which is it? I'd like to order an Ethernet IP module if it is compatible. Thanks! |
2/22/2019 6:05 PM | |
Thanks for the feedback. It's the only way we ever find out the reality of things. |
