10/21/2008 8:50 AM | |
Posts: 63 Rating:
Hi Wüstenräuber, I have put the proper tagname and .cfg file for ocx, in hardware profibus master are 1 & 2. And parameterization is correct also as per existing system, but you can check it in attachment and comment changes if required. thanks. |
1/10/2012 2:35 PM | |
Joined: 4/14/2010 Last visit: 12/11/2023 Posts: 518 Rating:
Greeting, Could you help us please regardig discussed issue i have perform above task but have still problem which tagname i can use for DP_DIAG see attached Thanks, Regard, Attachment3.zip (99 Downloads) |
