12/6/2011 3:33 PM | |
Joined: 3/21/2006 Last visit: 3/19/2025 Posts: 10239 Rating:
As 6GK7 343−1EX30−0XE0 doesn't "support" primary setup tool software in order to set IP address there you can't use it without MPI cable. Take a look at S7-CPs for Industrial Ethernet Configuring and Commissioning Manual Part A General Application(Chapter 3.9). for more. Best regards, Hristo Mihalev |
2 thankful Users |
12/7/2011 1:28 PM | |
Posts: 11 Rating:
Hi there Does anyone know where i can buy an MPI cable and how much does it cost. A 2nd hand working cable will also do!! Thanks |
12/7/2011 3:02 PM | |
Joined: 11/21/2007 Last visit: 3/16/2025 Posts: 2326 Rating:
Hello I feel the same source from which you got the CPU and CP, will be able to supply the So called MPI cable to you. The Least expensive variety is called PC USB Adapter. 6ES7972-0CB20-0XA0 - SIMATIC S7, PC ADAPTER USB
Pl See Link : http://support.automation.siemens.com/WW/view/en/14692974 Cheers Navnag |
There is no such thing as the last bug in a program |
12/7/2011 8:09 PM | |
Posts: 11 Rating:
THANKS... |
