7/29/2019 1:00 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello first check this FAQ: https://support.industry.siemens.com/cs/de/en/view/109759021 and you can try to disable the RuntimeSettings->Alarms-> automatic Update then do a recompile all and then try again and look also in the PLC alarms Tab in the HMI Alarms if the PLC Alarms are set correctly in the HMI. Bye Murof |
