6/26/2023 5:06 PM | |
Joined: 8/11/2022 Last visit: 3/31/2025 Posts: 1 Rating:
I continue to experience this issue. Navigating to user management first does not allow me to view my runtime project: only a grey screen is shown. The only way to correct this that I have found is to perform a full download to my HMI panel, which is not at all ideal during operation. Is there anything else that I can attempt? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/27/2023 08:37:15New subject after splitting |
6/27/2023 9:03 AM | |
Joined: 5/30/2022 Last visit: 4/16/2025 Posts: 634 Rating:
Hi zk104, I recommend you review the following.
If this information really helps, you could use the Rate function. |
6/27/2023 9:05 AM | |
Joined: 5/6/2022 Last visit: 4/16/2025 Posts: 585 Rating:
Hi zk104, What browsers have you tried? Does the same thing happen to you in all of them or only with one in particular (Crome, Internet explorer...)? Have you tried clearing cookies, clearing cache and so on...? I also recommend you review this FAQ that may be of help: "Which Windows functions must be activated in order to be able to install SIMATIC WinCC Unified?" Best regard! |
