12/26/2020 10:39 PM | |
Joined: 11/12/2018 Last visit: 12/2/2021 Posts: 3 Rating:
Dear Experts, Got this error while working on Node Red in IOT 2050. Refer attached and kindly advise. Thanks |
1/5/2021 5:34 PM | |
Joined: 12/12/2016 Last visit: 8/8/2022 Posts: 640 Rating:
Hello Chan, I've seen this problem before when using the S7-Nodes. Basically your device is being filled with logs and at some point you have no more space left on the device. /var/log/syslog and /var/log/daemon.log You can erase the content of these log files with following commands:
I added a script in the attachment that checks for filesize and deletes these logs when they are too large. You can install crontab on the IOT2050 and configure this script to run daily/weekly to prevent this from happening again. Hope this helps. Best regards! Attachmentdelete-logs.zip (179 Downloads) |
8/26/2021 6:20 PM | |
Joined: 7/23/2013 Last visit: 5/24/2022 Posts: 13 Rating:
Can you explain me how to install and configure the script step by step please. thanks |
