6/5/2020 10:44 AM | |
Joined: 4/28/2015 Last visit: 12/8/2023 Posts: 3298 Rating:
Hi, it looks like node-red crashed. You can try to restart the device and see if it is accessible afterwars. If not probably your flow is causing this crash. In this case you can follow this instruction to delete it. Can you share your flow? Best regards! |
6/5/2020 11:34 AM | |
Hmm that is really strange. Can you try to start it manually with node-red and see what the output is? Best regards! |
6/5/2020 11:46 AM | |
Joined: 11/14/2012 Last visit: 12/5/2023 Posts: 9 Rating:
Of course. I started it manually but the behaviour is still the same. |
6/5/2020 12:08 PM | |
From that it seems still running. Maybe there is some more output if you change the logging level to "trace" in /root/.node-red/settings.js. (https://nodered.org/docs/user-guide/runtime/logging) Try to change that and start node-red manually again. Best regards! |
