6/5/2011 12:09 PM | |
Posts: 691 Rating: (37) |
Dear Saravana kumar What I experienced is : Download to Test doesn't download the program fully . Because of memory size the name Test has been given . In this mode DBs are not downloaded in the CPU. This can be overtaken by Entire download in the CPU |
6/5/2011 2:01 PM | |
Joined: 3/18/2008 Last visit: 12/8/2023 Posts: 1750 Rating: (272) |
Dear shar, i think kumar is asking something else. May be i am wrong. I think he said that when he press Test mode on button he is not able to mointor some valure in CFC.he is not downloading program to test CPU. Kumar Correct me if am wrong? Any way i have also faced this similar Problem & want to the reason for same. |
VANDE MATARAM..... |
6/5/2011 2:10 PM | |
Dear shar, i think kumar is asking something else. May be i am wrong. I think he said that when he press Test mode on button he is not able to mointor some valure in CFC.he is not downloading program to test CPU. Kumar Correct me if am wrong? Any way i have also faced this similar Problem & want to the reason for same. Sorry for understanding it wrong. The reason behind not getting proper monitoring is because of the communication load. the communication load increases when you are monitoring all the blocks in a chart and open another chart for monitoring all the blocks again. I think when you are monitoring one chart then you hadn't got any problem, but monitoring a bunch of charts might have created the problem. The same issue is being discussed in another thread Online Monitoring not working properly |
6/5/2011 3:11 PM | |
Joined: 2/6/2009 Last visit: 1/7/2025 Posts: 939 Rating: (118) |
Dear shar, i think kumar is asking something else. May be i am wrong. I think he said that when he press Test mode on button he is not able to mointor some valure in CFC.he is not downloading program to test CPU. Kumar Correct me if am wrong? Any way i have also faced this similar Problem & want to the reason for same. Hi Amit, yes you are right. I have not downloded the program in test mode. I have done it in the normal way only.
_______________________________________________________________ |
6/5/2011 3:24 PM | |
Sorry for understanding it wrong. The reason behind not getting proper monitoring is because of the communication load. the communication load increases when you are monitoring all the blocks in a chart and open another chart for monitoring all the blocks again. I think when you are monitoring one chart then you hadn't got any problem, but monitoring a bunch of charts might have created the problem. The same issue is being discussed in another thread Online Monitoring not working properly Hi Shar, Thank you. Even when I tried to monitor single CFC also this problem is there. But I don't why after two three downloads it is working properly. While taking tries there will not be any problem to download again and again, But after commissiong how to do that?
