12/4/2015 10:55 AM | |
hi mfullen, I´m afraid to say you, that TIA is not supporting your module. it is too old Look at the list in following FAQ. On page 9 and 10 you find the supported IM151-1 modules. There is no 1BA01. Which devices and modules are supported by STEP 7 Professional and WinCC Professional in the TIA Portal?hope this helps, regards, |
12/4/2015 11:00 AM | |
Posts: 3 Rating:
Oh no! I didn't expect that Thank you for your time and help. |
5/12/2018 1:00 AM | |
Joined: 4/5/2018 Last visit: 5/2/2023 Posts: 14 Rating:
I got the same issue today. What were Your solution ? |
1/18/2019 10:14 PM | |
Joined: 4/18/2013 Last visit: 5/17/2023 Posts: 17 Rating:
I´m having the same issue with TIA Portal V13 and a IM-151 (6ES7 151-1AA02-0AB0). I imported the GSD for 6ES7 151-1AA0*-0AB0 found here: https://support.industry.siemens.com/cs/ww/en/view/652154
Are you saying that even if you use GSD files and import the IM-151-1 as an external device (not in hardware list) it will not comunicate? DP Master is a IM 151-8 PN CPU. I will try to add this CPU to a Step 7 V5.4 as a workaround... |
