2/21/2023 11:19 AM | |
Joined: 2/17/2020 Last visit: 3/22/2023 Posts: 738 Rating:
Hi, Please see: Defining the output format -> Numerical values Are you doing the tests simulating the UCP or downloading the project to the real panel? I have been able to test and it seems that when simulating the UCP, the Runtime shows the Normal Keyboard in case of Numeric Format configured, while with the real UCP, the Numeric Keyboard appears when clicking on the IO Field. |
If this post helped you in any way, please rate it positively. |
3/1/2023 11:04 AM | |
Joined: 4/13/2022 Last visit: 3/1/2023 Posts: 1 Rating:
@MattiG Have you found a solution to this problem? I am also experiencing the same problem. |
