1/24/2011 6:59 AM | |
Joined: 10/7/2005 Last visit: 5/29/2023 Posts: 2965 Rating:
Hello melsec- OB 36, 37& 38 do certainly NOT exist assystem related OB's in a CPU 944 and as such 9and asyou said) can't be found in the manual. I wonder though if someone simply used and programmed them like you would use and program a PB. I must admit that I never tried this in the good old S5 days, but Step5 certainly won't stop you from doing so. Perhaps worthwhile testing if this works should you have a 944 CPU handy (others may be able to verify this too). If it does,you treat these OB's like you treat a PB. I hope this helps and please let us know what you find out. |
Cheers |
