7/11/2024 6:25 AM | |
Joined: 3/5/2024 Last visit: 9/11/2024 Posts: 10 Rating: (0) |
Hi, I would try to create some application little bit diferent with unified, I want that when i have the mouse over some object this object change this size and make it bigger? thhere´s already some funciton for it? or how I can detect the mouse position? Thank you, BR, Issam ------------------------------------------------------------------------------------------ |
Last edited by: Wit_Moderator at: 07/11/2024 12:04:57New subject after splitting |
7/17/2024 10:07 AM | |
Joined: 2/25/2016 Last visit: 9/12/2024 Posts: 7 Rating: (2) |
You can do it with svghmi widget. It can detect hover event. You need combination of two "hmi-bind:transform" attributes. I've created an example for demonstrate it. But it will work only for svghmi widget. AttachmentDynamicSizeExample.zip (44 Downloads) |
