2/13/2009 10:25 PM | |
Posts: 2661 Rating:
Hi zapotek, You can do this in many ways... You can manipulate the Postion X & Position Y attributes in the object itself or you can change position attributes "outside" the object (in a button for example). In VBS you can use the Top and Left attributes. Find attached a simple example in VBS. In this exampleeverytime you click the button, the circle moves by 20 X and 20 Y. Regards AttachmentNewPdl1.ZIP (231 Downloads) |
Last edited by: Phantom75 at: 2/13/2009 10:28 PMLast edited by: Phantom75 at: 2/13/2009 10:26 PM |
2/16/2009 10:29 PM | |
Joined: 9/1/2005 Last visit: 8/24/2023 Posts: 4099 Rating:
closed cause question posted twice. The second thread with the subject how can i read an objets coordinates in graphics editor with a VB code? is published within the same conference . Best regards CS Moderator |
