9/26/2007 11:27 AM | |
Joined: 12/8/2006 Last visit: 11/27/2023 Posts: 170 Rating:
hi, 1) meaning of the letters "u." behind the archive value ----------------------------------------------------------------------- http://support.automation.siemens.com/WW/view/en/22286246 On 2007-09-12 there was probablyaconnection problem (wincc data manager to the plc). 2) different values ------------------------------ In the case of usingthe wincc option "redundancy", you have different optionsfor synchronization of tag logging. Please check the settigs in the editor "redundancy" of wincc control center. note: ---------- In the case of "synchronization of tag logging"entire database segments are copied from one server to the other server. Each server has his own connection to the plc causingthe minor differences intimestampand values of the archived tags. More informations about the segmentation of the wincc runtime database you will find in the faq: http://support.automation.siemens.com/WW/view/en/22273427 |
9/26/2007 2:28 PM | |
Posts: 145 Rating:
Ateam, Thanks for your quick reply. How can I resolve this, so as not to have minor differences in the time stamps and in the archived values? Best Regards |
10/1/2007 8:36 AM | |
Posts: 1776 Rating:
Hi, there is no possibillity ![]() April |
