5/18/2009 2:18 PM | |
Hi
Learn more about visualization - visit the HMI courses of Siemens AG! |
5/28/2009 6:07 PM | |
hi First thing i woud do: define a boolean retrun-value of TLGExport. The value will be false, i know. Second: try to read out the error-text of the function(should be "error.szText") Third: the function expected pointers,so work with pointers (as you did with FileName). Ich allways work with pointer by ODK, it does not like my variables. Yousay you work with a lower version of ODK as V7.0. The Doku say: "This function is only supported by WinCC version V6 SP4 or higher" |
6/22/2009 7:19 PM | |
Joined: 9/27/2006 Last visit: 7/11/2023 Posts: 47 Rating:
Hi Manuelze, Did you manage to get your function working? If you did, what was the problem and how you fixed? Thanks! |
7/6/2009 11:00 AM | |
Posts: 99 Rating:
No, it still doesn't work. |
