6/16/2011 8:12 PM | |
Joined: 9/27/2006 Last visit: 3/18/2025 Posts: 12344 Rating:
Hello Autodoc; The attached document shows he result of the search for your OLM part number in the Siemens Industry Mall (loo for it under that name in Google). The replacement suggested is the OLMP11. As I have personnally not been involved with your original OLM 12M, I can only suggest you study the following document showing the different topologies available with OLMP11/P12 at this version level and determine if they can correspond to the functionnalities of the OLM12M: -OLM V.4.0:http://support.automation.siemens.com/WW/view/en/30006392 -OLM12M: http://support.automation.siemens.com/WW/view/en/2260456 You could also look for refurbished units on the web, such as the one found here, to use as spare parts on your existing network: http://shop.softwerk.at/manufactur13,1942,OLM_12M_Plastik_f._Profibus.html Hope this helps, Daniel Chartier |
