8/12/2017 1:57 PM | |
Joined: 12/18/2014 Last visit: 1/20/2025 Posts: 34526 Rating: (4307)
The function is called "ON-/OFF-Delay". Have you ever created an example. The time value can be changed via the display, possible range 0-5999 seconds. AttachmentFunktion_G_(0BA7.Standard).zip (244 Downloads) |
8/12/2017 2:30 PM | |
I printed the diagram in a PDF file.
AttachmentFunktion_G_(0BA7.Standard).pdf (214 Downloads) |
8/12/2017 2:45 PM | |
Posts: 10 Rating: (0) |
Thanks a lot, will it work on 0ba6 module with 4 outputs? I don't need in & out indication I just need to adjust 4 timings Cheers |
8/12/2017 3:00 PM | |
Nothing next, I'm sorry, as I said I'm a newby here, I'm trying to learn something so I didn't want to bother you doing it all. Thanks for your help. Cheers |
8/12/2017 3:06 PM | |
In attachment a PDF file. Using 0BA6 with four applications.
AttachmentFunktion_G_(0BA6.Standard).pdf (226 Downloads) |
