9/26/2014 5:38 AM | |
Posts: 21 Rating: (0) |
Good day I should check again your steps. What the value of input current scaler did you set? With best Regards |
10/16/2014 6:44 PM | |
Posts: 2 Rating: (0) |
Hi, You can check the power supply of the Hall, make the +/- 15VDC is no offset. The error of +/-15VDCmustsmaller than+/- 0.02VDC. |
10/28/2014 2:30 PM | |
Joined: 3/17/2013 Last visit: 8/25/2024 Posts: 481 Rating: (43) |
Hi What is the Firmware with your CPU Regards, Vijay |
