7/5/2016 2:17 PM | |
Posts: 2 Rating:
Hello all I am not able to find the online accessible node in the TIA portal Wincc V13SP. However my SCADA project is running well with S7 300 CPU. I also check in Simatic Manager Step S7 V5.5 accessible nodes are not found. If I want to upload the s7 300 CPU programme. Please see the attached file for more clearity. please any know the answer of it ? Regarads, Ashwani ------------------------------------------------------------------------------------------ |
Last edited by: Ashwani1985 at: 7/5/2016 2:19:34 PMLast edited by: Min_Moderator at: 7/5/2016 4:21:45 PMNew subject after splitting |
7/5/2016 8:32 PM | |
Posts: 439 Rating:
Hello, Do you have a fixed IP address on your PC or PG? Did you disable your firewall and anti-virus? Are you connect directly to the device? Best regards, Hugo |
7/6/2016 6:47 AM | |
Joined: 5/12/2006 Last visit: 12/8/2023 Posts: 21963 Rating:
Hello, can you ping the IP of the PLC? Regards Christoph |
