12/27/2011 4:23 PM | |
Joined: 3/21/2006 Last visit: 3/2/2023 Posts: 10221 Rating:
Hello, Attach here a sketch drawing topology of profibus network. Meanwhile take a look at What should you watch out for when using the RS485 repeater in PROFIBUS and MPI bus systems? Best regards, Hristo Mihalev |
12/28/2011 9:41 AM | |
Joined: 10/7/2005 Last visit: 3/22/2023 Posts: 2962 Rating:
Hello Nos what is the part number of your 416-2DP? If it's an older one, it could very well be that 31 OP's is the maximum number of OP's it supports, so I suggestyou check the technical spec of it. If this is indeed the case and you need more OP's on it, I fear you'll have to upgrade to a newer 416 CPU (a 416-2NX05supports up to to 63 OP's for example) In any case, please disable "Panel is only master on the BUS"on every OP. I hope this helps |
Cheers |
1/4/2012 1:55 PM | |
Posts: 3037 Rating:
Hello, Do you have check the Profibus cable and the resistor of connectors? Tweety |
1/11/2012 3:27 PM | |
Posts: 3037 Rating:
Hello, You can ask the customer support for your communication behaviour. ---> customer support Tweety |
