4/23/2007 10:00 AM | |
Posts: 3149 Rating:
Hi perhaps you could use the WinCC Configuration Tool? You can find more informations about this tool in your WinCC online help nemo |
4/23/2007 1:26 PM | |
Posts: 1275 Rating:
Hi, If you what wish to find out is which were the last alarms, and their numbers? For that you can use the gmsgfunc. You should also check these FAQ's: 1, 2 and 3 out. There's also this post. Best regards, Danielle |
