8/23/2006 11:37 AM | |
Joined: 4/24/2006 Last visit: 5/17/2022 Posts: 8432 Rating:
Hi, Here is a faq about updating Operating System: http://support.automation.siemens.com/WW/view/en/19701610 What version of WinCC flexible incl. Service Packs and Hotfixes are you using? Best regards, Wizard |
8/23/2006 12:19 PM | |
Joined: 2/17/2006 Last visit: 6/21/2021 Posts: 35 Rating:
WinCC flexible 2005 without any SP. |
8/23/2006 12:22 PM | |
Posts: 3149 Rating:
Hi the actual SP can be found here: http://support.automation.siemens.com/WW/view/en/23059737 Do you use CF-cards in your panel? => have a try WITHOUT CF-cards nemo |
8/23/2006 12:45 PM | |
Yes there is card, but after first „Freezes” I remove loging from program. Card is inserted but not in use. |
8/23/2006 12:52 PM | |
Posts: 3149 Rating:
ok, then remove the card from your panel |
8/23/2006 3:45 PM | |
Do you think that this problem is with memory cards? |
8/23/2006 3:49 PM | |
Posts: 3149 Rating:
I had once this feature and removing my cf-card solved the problem.... |
