9/19/2009 8:59 AM | |
Joined: 3/21/2006 Last visit: 3/2/2023 Posts: 10221 Rating:
Hello, About necessary settings into panel, you could use SIMATIC HMI HMI Device OP 177B (WinCC flexible) (ID:21084461). Also there http://support.automation.siemens.com/WW/view/en/24109937 you'll find helpful info about connection between panel (WinCC Flex) and PLC. Hope this will helps. Best regards, Hristo Mihalev |
9/19/2009 12:52 PM | |
Hello, Aaa, maybe you mean How can you transfer data via a USB cable from a configuration computer to a Windows-based operator panel? (Entry ID:22408158), plus Which USB master-master cables are recommended for the configuration download from WinCC flexible/ProTool to a Windows CE panel? (Entry ID:19142034).Unfortunately I don't have examples. To be honest, even I didn' try this way. Regards, Hristo Mihalev |
Last edited by: O_Moderator at: 9/24/2009 3:23 PMLast edited by: O_Moderator at: 9/24/2009 3:19 PMlink edited |
2/24/2011 7:33 AM | |
Joined: 10/7/2005 Last visit: 3/30/2023 Posts: 2962 Rating:
Hellois_razi perhaps one of thelinks below contains a suitable solution for what you want to do: WinCC flexible ES -- Creating HMI configurations -- Using archives How do you integrate an HMI operator panel into a local network? I hope this helps |
Cheers |
