1/15/2007 12:29 PM | |
Posts: 3149 Rating:
Hi perhaps can the following FAQ give some hints? Which cable and which COM-portare you using? nemo sorry, I forgot to add the link - I unfortunately don´t havean OP3: http://support.automation.siemens.com/WW/view/en/15178263 http://support.automation.siemens.com/WW/view/en/13396821 |
1/15/2007 2:30 PM | |
Posts: 95 Rating:
how did you put the op3 in the donwload mode ? using standard configured screens ? |
1/15/2007 4:03 PM | |
Posts: 218 Rating:
Hey, Click here Click to find OP3 manual, chapter 14 contains the transfer info Greetz Jeebs |
2/1/2007 4:17 PM | |
Posts: 3149 Rating:
Hi, perhaps this FAQ helps? http://support.automation.siemens.com/WW/view/en/13393116 nemo |
2/1/2007 4:32 PM | |
Posts: 13 Rating:
from prosave I can't choose OP3... |
2/2/2007 12:57 PM | |
Posts: 3149 Rating:
Hi do you have another cable? Or you could check the cable/conections http://support.automation.siemens.com/WW/view/en/21401061 http://support.automation.siemens.com/WW/view/en/21925297 did you already try to load via MPI? http://support.automation.siemens.com/WW/view/en/291294 http://support.automation.siemens.com/WW/view/en/21923867 nemo |
2/2/2007 1:41 PM | |
Posts: 3149 Rating:
okay I thought that communication in principle did not work. Did you already try MPI? nemo |
