11/30/2012 7:22 AM | |
Posts: 9 Rating:
Hi All! I have an new problem. We have one OP5 HMI. I would like upload the actual project, and must be made a new application. Which I know programm upload and create a new app?
11/30/2012 11:00 AM | |
Joined: 4/22/2010 Last visit: 2/26/2025 Posts: 5697 Rating:
Hello, I think you're better off creating a new project with modern panel. If you succeed in uploading, then you have next problem, you cannot edit the program. Try to get the original files or make new program. See also here Regards, Marcjan |
Problem solved? |
11/30/2012 4:30 PM | |
Posts: 9 Rating:
Hi! Good idea! Only problem, that must the earlier, because I don't want rewrite the complete app. The source of the app not available and I don't know what is inside function etc. I know, that use the operator. Thx for answer
11/30/2012 5:24 PM | |
Hello, When you read the thread i linked to, you must see that there are not mutch options Had the same situation many times and for me the best option was write new HMI program. Do you have the PLC program? Is there some operator that can explain to you how it used to work? Believe me you can try for weeks to get the data out of the OP5 you can make new HMI in 1 or 2 day's. Regards, Marcjan |
Problem solved? |
12/1/2012 8:36 AM | |
Posts: 9 Rating:
I tried now the Context for programme. I have the PLC program. I will made the modification, and I create an new app. Thx for your helping. |
