8/12/2008 4:44 AM | |
Posts: 17 Rating: (0) |
Hi everyone, Is it possible to backup a program from an OP7 DP, if posible how Can I do it which cable will I use. Thanks in advance. Kid |
8/12/2008 4:50 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating: (121) |
Hi, you can use ProSave to make a backup from the OP7. But notes: You can not edit this file -> for sample with ProTool! -> http://support.automation.siemens.com/WW/view/en/10347815 You need the following wire: -> 6XV1440-2KH32 The best are look to this FAQ -> http://support.automation.siemens.com/WW/view/en/26588748 regards, |
