10/28/2013 3:49 AM | |
Joined: 5/28/2008 Last visit: 8/31/2024 Posts: 4515 Rating:
Hello, You will need Protool Pro to program this panel And the cable needed is6XV1 440 - 2K ... . The following length code applies: 6XV1 440 - 2K x ab Here's bellow you will found how to make this cable: What is the serial cable assignment for transferring the configuration to an RMOS operator panel? You will connect this cable to COM port of your PC and 15-pin interface (OP7 side) The 9-pin interface at OP7 is for connection to controller via RS485 (MPI / Profibus). Hope this helps. |
Ayman Elotaify |
10/28/2013 8:43 AM | |
Joined: 8/16/2010 Last visit: 7/25/2024 Posts: 636 Rating:
Ok. But, how to install protool on windows 7? |
10/28/2013 8:46 AM | |
Joined: 1/21/2013 Last visit: 6/6/2024 Posts: 4620 Rating:
Hi Milosh, Take a look: Protool on Windows 7 Ultimate 32-bit - Siemens Industry Online ... Which versions of SIMATIC ProTool/Lite, SIMATIC ProTool and SIMATIC ProTool/Pro are compatible with which Windows operating systems? |
10/28/2013 9:28 AM | |
Thanks a lot. I will try and inform you... |
10/28/2013 9:30 AM | |
Hi Milosh, Let us know how it goes |
10/28/2013 9:31 AM | |
Hello, Try with other MS OS. You can try with XP. It will work.
Ayman Elotaify |
