1/16/2008 2:31 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, are you sure that the MPI cable are OK? did you check the baud rate? are the interface of the plc ok? regards, |
8/25/2017 10:50 AM | |
Joined: 6/19/2017 Last visit: 3/27/2023 Posts: 6656 Rating:
New question published by dgka is split to a separate thread with the subject Can i check Baud rate,Parity,Data bits and stop bit in OP7 - DP? . Best regards |
