3/17/2012 8:35 PM | |
Joined: 3/14/2012 Last visit: 2/7/2025 Posts: 22 Rating:
I put two resistors ON on the connectors |
3/18/2012 6:24 AM | |
Joined: 3/21/2006 Last visit: 2/10/2025 Posts: 10239 Rating:
Hello, Both connectors should be in ON position. Did you try to 'Reset to factory settings' using ProSave.pdf then to make OS update and then to download directly your project? best regards, Hristo Mihalev |
3/4/2013 1:34 PM | |
Posts: 3037 Rating:
Hello, Here you can find more for transfer and communication about Profibus. How can you transfer a WinCC flexible project via MPI/PROFIBUS to a Windows-based panel? How do you configure a connection between WinCC flexible Runtime (PC/Panel) and a SIMATIC S7-300/S7400 via PROFIBUS/MPI? Tweety |
