12/19/2013 1:28 PM | |
Joined: 3/20/2013 Last visit: 3/18/2025 Posts: 676 Rating:
Hey Milos!
So your SCADA system is capable to act as OPC client?
FAQ And with your Simatic Net software are coming some documentation PDFs. Somewhere around : START -> Siemens automation -> Simatic -> simatic net -> "xxx.pdf" (project PC station...) sry i do not have the exact path right here. |
Best Regards, |
12/19/2013 1:35 PM | |
Posts: 1368 Rating:
Hey Milos, here http://support.automation.siemens.com/WW/view/de/77378184/0/en you will find more informations about configuration of the PC Station and here some additional infos for OPC http://support.automation.siemens.com/WW/view/de/77376110/0/en have fun... Pittiplatsch |
12/19/2013 1:36 PM | |
Posts: 146 Rating:
Dear Fafner, Thanks for helping again Our web based SCADA (developed by our company) can act as OPC client and our intention is to collect some variables from S7-400 PLC. Thanks for help again. I will try this and let you know if I found a solution. Can this be tested maybe by using PLCSIM? Just to see in OPC scout some variables changing? PLC is not available for testing. Best regards Milos
