8/23/2007 11:03 AM | |
Posts: 5822 Rating:
Hello, well, I wonder does this error also appear if you use the SIMATIC NET OPC Scout? If so you may have two different Problems, you either need to install Hotfix 1 to SIMATIC NET CD 2005, which you can find at: SIMATIC NET CD Edition 2006 Hotfix 3, CD Edition 2005 Hotfix 1, CD 11/2003 SP 1, CD 11/2002 SP 1, PC-Software V6.0 SP5 HF2 or you have a Problem with this installation at all. If you have another OPC Client and the OPC Scout works, check your OPC Client. Best regards J_Bell |
