7/6/2008 3:08 PM | |||
Joined: 9/27/2006 Last visit: 1/25/2025 Posts: 12330 Rating: (2702) |
Hello NI3; How are you setting up communications between your WinCC PC and the S7-400? If you are using any Simatic Net software for a driver, there is a SimaticOPC server available for every package; here is an example:
If you need something different, I would look at the major OPC vendors: Kepware, Matricon, Top Server... Hope this helps, Daniel Chartier |
7/8/2008 5:56 AM | |
Posts: 487 Rating: (36) |
Hi Using a profibus PC card you can connect directly to the S7 400 Eric |
