12/7/2020 4:16 PM | |
Hello if you use the S71200 or S71500 PLC as OPC UA Server then you need a Runtime License for it. Here is a Free Example for a Test Client: https://support.industry.siemens.com/cs/de/en/view/109737901 Or you use another standard Test Client like UAExpert Bye Murof |
