9/16/2016 12:30 PM | |
Posts: 19 Rating: (0) |
hello, I want to open a .psb file that i have backup from a TP 177B. haw? |
9/16/2016 12:41 PM | |
Joined: 9/28/2005 Last visit: 10/22/2024 Posts: 2957 Rating: (242)
Hi, You can't open it or convert it to editable format. You can only use it with Prosave software to restore backup on the same type of HMI. Similar problem to yours is discussed here https://support.industry.siemens.com/tf/ww/en/posts/53955/ |
Last edited by: Darius at: 9/16/2016 12:42:19 PMLast edited by: Darius at: 9/16/2016 12:43:49 PMBest regards, |
9/16/2016 12:44 PM | |
Joined: 1/21/2016 Last visit: 4/22/2023 Posts: 83 Rating: (1) |
its aback up from prosave you can only retrieve it with same hmi |
Amr Ali |
9/16/2016 1:08 PM | |
how i can convert it to editable format? there is a software? |
9/16/2016 1:12 PM | |
Joined: 5/12/2006 Last visit: 10/22/2024 Posts: 22431 Rating: (3028) |
no , no conversion possible! There exists no tool to get a engineering project from a psb file. |
3/26/2018 11:02 PM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (172) |
New question published by DPQ_Grial is split to a separate thread with the subject Is it possible to load a .PSB or .MWP backup into the simulation software?. Best regards |
