3/13/2017 10:25 AM | |
Posts: 3093 Rating:
Which protocol are you going to use? |
3/13/2017 10:48 AM | |
Posts: 47 Rating:
PROFINET |
3/13/2017 10:49 AM | |
Joined: 7/9/2015 Last visit: 3/21/2025 Posts: 4204 Rating:
Hi, for Open User Communication you can use the instructions T_CON, TSEND, TSEND_C and so on. You can communicate to other Devices via TCP/IP, UDP, ISO-on-TCP. Please check the following general link: How do you configure open IE communication via the integrated PN/IE interface of the CPU or via an Industrial Ethernet CP?Regards, Towome |
3/13/2017 11:31 AM | |
Posts: 47 Rating:
Thank you fella, Is there a new version of the wizard for this. as the old one (https://support.industry.siemens.com/cs/document/98957840/wizard-for-creating-connection-data-for-open-tcp-ip-communication-(open-communication-wizard)-?lc=en-de) Does not run tia projects. |
