9/6/2007 12:15 PM | |
Posts: 3149 Rating: (171)
Hi which WinCC version are you using? Did you install Basic Process Control as well? Does this happen in a new project too? nemo |
9/6/2007 1:33 PM | |
Posts: 31 Rating: (0) |
Here goes the logs. In this PC, i have no license, im running with no license, until the license that we buy arrives. Hope you can help me...
AttachmentDiagnose.zip (162 Downloads) |
9/6/2007 2:44 PM | |
Hi please check in your WinCC -project folder whether e.g. this PDL is available: 65535,06.09.2007,12:32:17:239,1001003,8,,DT2,PDLRuntimeSystem,,,0,0,0,Picture not found (@PTN_Group2.pdl),,, 65535,06.09.2007,12:32:17:348,1001003,8,,DT2,PDLRuntimeSystem,,,0,0,0,Picture not found (@PTN_Group2.pdl),,, 65535,06.09.2007,12:32:17:364,1001003,8,,DT2,PDLRuntimeSystem,,,0,0,0,Picture not found (@PTN_Group2.pdl),,, @PTN_Complete_Exercise.pdl 255,06.09.2007,12:18:10:267,1007005,4,,DT2,SCRIPT,Fault in LoadFunktion AcknowledgeMessage error: 'AcknowledgeMessage': doubly defined function 255,06.09.2007,12:18:10:298,1007005,4,,DT2,SCRIPT,Fault in LoadFunktion GetLinkedVariable error: 'GetLinkedVariable': doubly defined function 255,06.09.2007,12:18:10:298,1007005,4,,DT2,SCRIPT,Fault in LoadFunktion GetLocalPicture error: 'GetLocalPicture': doubly defined function 255,06.09.2007,12:18:10:314,1007005,4,,DT2,SCRIPT,Fault in LoadFunktion GetParentPicture error: 'GetParentPicture': doubly defined function 255,06.09.2007,12:18:10:314,1007005,4,,DT2,SCRIPT,Fault in LoadFunktion GetParentPictureWindow error: 'GetParentPictureWindow': doubly defined function 255,06.09.2007,12:18:10:345,1007005,4,,DT2,SCRIPT,Fault in LoadFunktion Registry2 error: 'Registry2': doubly defined function 255, => 2007-09-06 12:11:31,387 ERROR Cannot connect to "PLC1": Errorcode 0xFFDF 4110! => => http://support.automation.siemens.com/WW/view/en/11965771 => http://support.automation.siemens.com/WW/view/en/16622456 |
