8/30/2013 7:23 PM | |
Posts: 15 Rating:
Initially, I had to archive and retrieve because an issue with the SQL database causes Simatic Manager to lose an entire server reference in themultiproject tree. Having the same issue after archiving and retrieving on the same computer. Not sure why the system doesn't handle this for you. It looks like it is expected and pretty typical. If you hit help on the assign server window, it will bring up the bad news and all the additional work you will have to do. (Also attached a pdf scan). Whatever you do, don't sever the connection to your actual servers! Good luck! Attachment20130830111135123.pdf (79 Downloads) |
