11/18/2008 4:44 AM | |
Posts: 62 Rating:
Hi all, AttachmentOverviewAreaProblem.zip (63 Downloads) |
11/18/2008 4:45 AM | |
Posts: 62 Rating:
Sorry. I am using WinCC 6.0 SP4 with Basic process control on XP Pro. Yai |
11/18/2008 3:55 PM | |
hi Is it possible, that you created your picture tree from "Plant Hierarchy", then you has selected the wrong "Os area". Plaese check it: 1. klick at the menübar at "View" > "Plant View" 2. Select one Hierarchie Folder and then klick in the menübar at "options" > "Plant Hierarchie" > "Settings" 3. Select as OS area this, where the pictures are. inyour case area 1 4. complile the OS with "Picture tree", "Entrie OS" and "With memory reset" If that not helps, tell me. Please post the link to the other thread. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
11/20/2008 3:16 AM | |
Posts: 62 Rating:
Hi cumulus, My project is only WinCC+Basic process control and I created overview area directly from Picture Tree Manager. I do not use PCS7. Any possible cause? Thank you Yai |
