9/10/2019 7:05 AM | |
Joined: 4/28/2015 Last visit: 9/20/2022 Posts: 1278 Rating:
Hi, do you use S120? Have you tried it like described here in the FAQ?: https://support.industry.siemens.com/cs/de/en/view/109480518 It is stated that you should change the fan and then set p251 and p254 to 0 - then the warning should be gone. |
Best regards, |
9/10/2019 9:41 AM | |
Hi, you need to switch off the drive before changing p251. |
Best regards, |
9/10/2019 10:06 AM | |
Posts: 153 Rating:
Check r2=ready to switch ON (ready status) and change. |
