10/18/2018 3:29 PM | |
Joined: 2/4/2018 Last visit: 9/19/2023 Posts: 55 Rating:
Even with the memory card. regards |
Regards |
10/18/2018 3:32 PM | |
Joined: 10/11/2006 Last visit: 12/6/2023 Posts: 5718 Rating:
Hello, Please check that have you saved you parameterization RAM to ROM.If you are using a memory card make sure there is no empty project stored on the card, otherwise it will be loaded after each power cycle. You can try to run the G120 without memory card. Even if you have stored the last parameterization on the memory card? You can find an FAQ mentioning the different storage possibilities of the G120. https://support.industry.siemens.com/cs/ww/de/view/43512514/en |
With best regards, |
11/1/2018 6:32 PM | |
thx , very helpful. |
Regards |
