11/14/2018 7:34 PM | |
Joined: 9/17/2017 Last visit: 1/17/2023 Posts: 17 Rating:
Hello How can I check parity of the real value. Example: When the parity is 1 then true, if not false. Thank you. |
11/14/2018 7:50 PM | |
Posts: 2826 Rating:
Hello.
Parity is associated with communications. There it does not matter if you are having a REAL or a tweet text message. See also: https://en.wikipedia.org/wiki/Parity_bit Please fill in some context. What are you using it for? How is the 32-bits broken up?.. or something else? BR |
