4/14/2012 3:34 PM | |
Joined: 12/22/2006 Last visit: 1/25/2022 Posts: 1742 Rating: (309) |
Hello, I guess that you want to use another timer each time you call the FC. Have a look to the file in annex. The block is only to show a basic example, don't expect a high featured block ... It showsanother way consisting ofusing a Timer embedded as multiinstance in a function block. Each call to the FB implies the usage of a new internal Timer in the function bloc. May be it solves your issue. AttachmentF1.pdf (528 Downloads) |
Best regards |
